Hallo, ich habe ein Problem, wenn ich auf Export im Lexware Businessplan gehe. Folgende Fehlermeldung wird ausgegeben:
The switch --page-offset, is not support using unpatched qt, and will be ignored.The switch --header-line, is not support using unpatched qt, and will be ignored.The switch --header-spacing, is not support using unpatched qt, and will be ignored.The switch --header-right, is not support using unpatched qt, and will be ignored.The switch --footer-html, is not support using unpatched qt, and will be ignored.The switch --footer-spacing, is not support using unpatched qt, and will be ignored.Unknown long argument --xsl-style-sheet Name: wkhtmltopdf 0.9.9 Synopsis: wkhtmltopdf [OPTIONS]…
[More input files] Description: Converts one or more HTML pages into a PDF document, not using wkhtmltopdf patched qt. General Options: --collate Collate when printing multiple copies --copies Number of copies to print into the pdf file (default 1) --extended-help Display more extensive help, detailing less common command switches -h, --help Display help -O, --orientation Set orientation to Landscape or Portrait -s, --page-size Set paper size to: A4, Letter, etc. --password HTTP Authentication password -p, --proxy Use a proxy -q, --quiet Be less verbose --username HTTP Authentication username -V, --version Output version information an exit Reduced Functionality: This version of wkhtmltopdf has been compiled against a version of QT without the wkhtmltopdf patches. Therefore some features are missing, if you need these features please use the static version. Currently the list of features only supported with patch QT includes: * Printing more then one HTML document into a PDF file. * Running without an X11 server. * Adding a document outline to the PDF file. * Adding headers and footers to the PDF file. * Generating a table of contents. * Adding links in the generated PDF file. * Printing using the screen media-type. * Disabling the smart shrink feature of webkit. Contact: If you experience bugs or want to request new features please visit , if you have any problems or comments please feel free to contact me: see
Ist das ein Problem bei mir oder der Software?
